Fuel gauge went to zero ?
  • Fuel gauge went to zero ?
    On my 1994 21' CConsole - the fuel needle was at 1/2 full, then
    when I re started the engine - the needle's at zero.
    Likely cause and fix ?
    This should help you troubleshoot it.
    http://www.tflx.com/tech.html
      Does anyone know where the ground connection is for the fuel gauge
      on a 93-94' Mako 21' C Console ?
      Where to gain access to the ground to check for connection ?
        That really depends on how the gauge is wired. It may be on a buss board under a console. But it is probably on the fuel tank beside the sending unit. You should be able to access this through an access panel in the deck or from an access panel under the console.
        Cliff
