Twin 200hp 1987 Yamahas----4800 on port and 5100 on stbd at wot. The props are ss and cupped but there is no name or dimension posted on either prop. Is there anyone out there with a similar setup? What are you running for props? How well do they perform?
props for 1987 Mako 261
Hmmm....dont know dia., but its the standard size. 1/4" or so in dia is not going to make a difference.
As far as fuel consumption, we cruise at 4000, burning 20gph @ 29-30 knots depending on wind. Pretty much get 1.5nmpg through the 3000 range, maybe a hair better at around 35-3600 so it seems.
1987 261 with 1997 200 yams. 15 1/4 x 17 yam SWSeries props. WOT is 5500rpm with a decent load, 46-48mph max and average fuel burn with these carbed engines is 1.5 -1.65 mpg. The engines are mounted 2 holes up and the counter foot is on the starboard side (it backs much better). Hole shot is outstanding, I plane easily at 3600 rpm with a heavy fishing load.
