Bottom Paint
  • Bottom Paint
    I've got a question for you experts. My 1975 23' Mako CC has blue anti-fouling paint on the bottom. I keep my boat on a trailer all the time and only in the water on a per day basis. Is this paint slowing me down or reducing the performance/speed of the boat? By how much and should I care?
    Houston, TX[br]1975 Mako 23
    Bottom paint dosn't slow you down enough to even matter. A customer of mine spent 3500 bucks having us strip the paint off his hull and gained a whopping knot.
      I will disagree on the effects of bottom paint. Of course it depends on how much is there. I do know for a fact that on one brand new boat it slowed the boat by 3 NMPH. On another boat that was stripped and redone, the speed to plane was reduced and the top end gained.
        It depends on a couple of factors:
        1. Type of paint used.
        2. How much paint is there.
        If it's been on for a while, it probably isn't doing much to slow you down. An Ablative paint, such as MICRON will wear off over the years.
        As already stated, it's EXPENSIVE to have it removed professionally. I just sanded mine down (wearing a respirator!) as much as possible and then reapplied fresh MICRON CSC to the areas that are exposed for the sake of appearance: transom, forward keel/bow and the sides. The rest I ignore.
        Prop Blast
          Not that my expertise is computational fluid dynamics however, with certainty I can say any substrate with a pronounced porosity is going to contribute to the drag coefficient of your hull. This being said, yes, you will be able to tell a difference in boat speed but not handling between a clean glass hull and one that’s been painted. This is especially true if your paint is the typical two-part epoxy formula that’s been applied with a roller (dried finish kind of a rough orange peel texture). If the boat is used for anything other than racing, I wouldn’t be concerned.
            Thanks for your responses. I don't think I'm gonna worry about it.
