need prop HELP 22' / 225hp Evinrude
  • need prop HELP 22' / 225hp Evinrude
    1974 Mako Model Specifications
    Mako 22B 21' - 1800 lbs 51 Gallons
    It has a 1991 225hp Evinrude. Prop is wasted just got boat..
    please help..
    thanks
    I run a 17 x 14 1/4 on my 224 with a 225. If I remember right my 224 has a significantly deeper V in the hull than a 22B and mine is also significantly heavier when loaded with fuel and gear so my setup might not work for you.
      great thanks.... but it might work for me becuse i think mine is water logged... when the prop was in fair shape it just didnt feel like i was going anywhere i thought when i bought it. it was going to screm but turned out to be a slug....
        Your motor should run @5500 rpms at full throttle and a full load. If you realy want to understand props there is a great web site called power tech. This site will explain rake, pitch, cup and all the things to help you get max performance.
          thank you gary i will check it out....
            Had a 1978 22B. 1987 Evinrude 225. My numbers were:
            - 14 1/4 x 19 SS (Don't remember except was not SST but was a OMC prop)
            - 3800 RPM, 30 MPH
            - 5500 RPM WOT, 43 MPH
            - 2.5 MPG Average at cruise.
              Alcedo
              thanks for your help thats the most info yet...[]
                1976 mako for sale $5,700.00
