Fuel Tank Grounding
  • Fuel Tank Grounding
    It appears that both of my fuel tanks have ground wires that go. um, no where.[|)] Where should they go.
    Also when setting up the fuel feeds from two tanks , is it ok to have a shut off valve on each and go to a tee fitting or should I use a single specific type valve with a shut off for each feed. My fittings are all 3/8".
    Thanks-
    Bob
    Thanks-
    Bob
    Very nice site...!!!!
    The grounds should go to the water if you have a thru hull grounding
    strap but if not they should go to the main ground lug. Not to the
    battery.
    As far as the fuel goes the ABYC states that you can not have a hose
    going to a shut off valve but that it is to be hard piped to the tank
    but this is usualy never the case with smaller boats so a accesible
    place would work just fine. Two valves is better as you always want to
    keep things as fail safe as possible, make sure the valves are rated
    for fuel transfer and have no restrictions in them...
    thanks
    DD
    On 02 @ 20\'
      There is no thru hull ground. So, this means that I will have a ground going to the Ground buss from each tank and a ground for each fuel guage correct? Just want to be sure.
      thanks-
      Bob
        Those words and knowledge sound oh too familiar. Is that you Dago? If so,[] nice to have you. I think you have much to offer even though you are brand-x owner.[]
          Hey Rich,
          that didnt take long and i was trying to be sneaky[]
          way cool site.
          thanks
          DD
          On 02 @ 20\'
