Caulk
  • Caulk
    I have a '97 Mako 191. Some of the caulk in the seams is hard and cracked. What do you recommend for replacement?
    [email protected]
    Depends which seams you want to seal (above or below the water line?) and if you want to get into those seams again. For a fairly perminate seal use 5200. If you will need to open it up again, marine silicone is OK. Read the labels and follow the directions. 5200 is messy and takes 7 days to completely cure unless you get the fast curing 5200 which takes if, I remember correctly, about 2 days. They say it's the same seal and bond but usually a slower cure means a harder better seal so I don't know if I should believe the labels on that one. Why would they continue to sell the regular 5200??
    Hope this helps -
