Cutting of rubrail ends.
  • Cutting of rubrail ends.
    I'm about to install the rubrail on my 17 but just ordered the end caps. Should I cut the ends flush with the transom or leave a 1/4 inch extra??? I don't want to install the end caps and then have a gap left or have to trim the rubrail. Also what is the best tool to use in order to cut. I heard someone say mitersaw. There has to be a better way to get a nice straight cut. Thanksid="Arial">id="size3">
    what did you end up doing,
    i just put the rubrail on my 17 and left 6" hangin off the back becuase i cant find the end cap?
      where did you find the end cap??
        Cutting.....Have you tried a PVC cutter tool?
          they end up shrinking a little over time. cut them just a tad long if you can get away with it.....
            Unless you do what I did on my very first project. I put my rub rail on in January and by July it was wavy as he,ll. It grew probably 3/16 to 1/4". Had to pull it off, resurrect and reinstall.
              its not so much cutting it, i actually just brought back a really old thread hoping he was still around to see how he finished the end. i'm looking for end caps or something to finish off where the rubrail ends at the transom rather than wrapping around
                  I cut them flush with the transom...can't remember if I used the big pruning shears or the craftsman hose cutters.
                    I purchased inexpensive end caps to cover the ends. I think they were from Taco.
                    http://www.jamestowndistributors.com...d+Cap+F90-0001
                    Keyman[br]Paoli, PA
                      in case your wondering what happend check my thread in projects,i found some ss caps from prime industries
