Gas Tank
  • Gas Tank
    I have the foam cut but i still can't pull it out. Is there anything else holding it in or due you have to pull really hard? Is there a better way of pulling it out? I don't have a chain fall.
    Panama City Beach Fl
    Did you back out the screws that have it lagged into the stringers? If you've done that, then you have to pull really hard. You'll need a come-along and some 4x4's. I've also seen people use a hydraulic house jack set on some 2x8s hooked to a chain to pop it out. There is foam beneath it that is still holding on for dear life.
      Ya, I have pulled out the bolts. I will have to invested in a come-along though. Thanks for the info.
